Whats involved in replacing the horn on a 05 GU 4.2td? Havent even looked at it yet,but thinking of going to the wreckers and getting something/anything better!
Is it just a simple 2 pin pull out old & plug in new?
Just a temp fix in time I will get a stebel I think.
Cheers.
Cheers LittleJohn. Well it sounds like someone was having a little fun when designing the horn tone!
Hi NOTAR
Suggest you check out these guys for replacement horn(s): eBay Australia Shop - Online Auto Parts: Car Horns, Bike Horn, Air Horn
I've replaced both of my OEM horns with twin air horns (Nautalis style) which are 139db (loud!). Very simple to install, just need to extend the existing wiring to reach the terminals, also need to upgrade the main horn fuse to a 40+ amp.
Let's just say that you won't be ignored when you use them! :D
Mike
