1 - 11 of 11 Posts
Wondering if anyone can tell me if it's possible to re-wire the antenna switch so that it can be placed in a full-up/full-down position rather than the full-up/half-down position.
I understand the earlier models had full-up/full-down function - I'd like to revert mine to this option if it's possible.
Dave.
NISSAN GU PATROL
Im sure its possible, but without looking at the wiring diagram and actualy playing around with some of the wiring and switch i couldnt say exactly how to do it.
But definately do-able
There was a thread on here within the last 3 or 4 months on that. I think the dude was an Accessories Installer or something. Knew his stuff about installing Head Units etc anyway.
Try a search I'm sure you'll get a hit.
It's possible. I put an extra switch on mine so can do full up/ half/ full down. Left the normal switch as is and added a on off switch to the blue wire on the head unit (it's an aftermarket unit though).
Aerial control
I took a simpler option and put a switch (in the cab) in the earth line from the OEM aerial drive unit. I can stop the aerial motor working at any spot. So I leave it fully up in the country and at half mast in the city. And, of course, no retracting when the ignition is turned off. The half/full selector still works when the switch is closed.
NISSAN GU PATROL
Thats what i want to do, im just trying to find a three position switch to replace the original with.
That's what I did with mine when I installed my replacement head unit. Just cut one of the wires and routed it to a switch that I installed in the bottom of dash at the transmision console.
Ray
Aldo look on ebay etx under arb switches etc and youl fins a dpdt illuminated switch on there somehwere otherwise go to ur nearest auto electrician or autobarn etc and they should hav something there for u, i got my switch through WES components they are about $16 each, google wes components i think they sell to public
1 - 11 of 11 Posts
