1 - 10 of 10 Posts
I often read on forums how effective the Patrol lsd's are but i belive the later GU's have a different (more conventional) design to the earlier GU's and previous Patrols
I wonder if the later version is as effective as the earlier design ?
Regards Don
Regards Don
From what year model are you talking? Mine definitely won't spin only one wheel on dry bitumen, it swings out sideways real nice when u stand on it. I spose 4wding is different but bitumen has plenty of resistance.
I would be stuck in the water still on that track that goes from Cape Leveque and Derby if it not for the effectiveness of the LSD and a bit of left foot braking!
Leroy
Mine did occasionally spin one wheel with 35's. Mine is a 2002 gu ute. I solved that problem with a $5 shim in the clutch pack. 4 and half years later still works like magic. Never singles up the bush with one wheel on the ground but still lets go around bitumen round abouts. A very cheap option to a diff lock.:p
Nissan GU
Hey slatey,
Do you have anymore info on that shim you installed e.g Make, Where to purchase etc.
Cheers.
It looks like the break point might be 03/2003 (for the H233 diff anyway) but it could be back as far as 09/2001 depending on the spec of the vehicle
Regards Don
Hey slatey,
Cheers.
I sourced the shim from patrolapart in lilydale, vic.
There number is 0397359099. They should be able to freight it to perth pretty cheap as it weighs next to nothing. They send 3.9 diff gears over that way regularly to brunwick diesel for there chev conversions. Give them a call. The price may of changed in 4 years but it shouldnt be much.
Hope this helps
These illustrations shows the early type (with the good reputation) and the later conventional type (03/2003 onwards but possibly earlier)
Regards Don
1 - 10 of 10 Posts
