1 - 12 of 12 Posts
Currently in PAD rehab
Greetings.
I was getting sick of the dull parkers and indicators in my Nissan Bullbar so i bought a set of ADR approved LED replacements from OzLED (Check the vendors section).
The model is 200CAW.
This is what the indicators and parker unit looks like before. Mine often filled up with water and the lights often didnt work due to the amount of crap in there.
Click on the photos to see a larger one, ive just made these thumbnails to help out the people with low bandwidth.
First thing to do is to remove the two screws that hold the existing light assembly in, and pull the whole light assembly forward.
There are 3 wires which go to the original assembly. The loom loops up over the horn. I just cut the wires and put the old assembly aside.
The new assembly comes in a box with a bracket.
Depending on your wiring, this is how it should look either interfacing to the wiring extension, or the wiring before the extension.
or
Solder and tape everything up.
The bracket fits into the existing insert. I replaced the screws with some slightly longer ones. If the hole in the plastic is a bit chewed out, just use larger screws, or put some clips behind. Clip the light into the bracket. The light is sealed, and looks very sturdy.
Pretty easy, and looks pretty good id say. As a bonus if you buy from OzLED its ADR approved!
Ask any questions, look forward to your comments.
Discussion Starter · #5 · (Edited)
In the interest of posting the price here and then people reading it later when it is wrong id suggest PM'ing OzLED directly to get the current price. They were about $30 ea 20 Oct 2010 plus postage.
The only other thing i would probably think about doing would be to put some silicon around the outside of the assembly, but its not really required as it is a sealed unit. The screws pretty well line up with the existing holes for the factory lights, the whole job took me about 15 mins, most of that was me looking for the soldering iron and working out which wires go where. The white wire is earth on the LED light, which goes to the black car earth wire.
The others are in the photos..
nissan gu td42
I did the same mod some 3 years ago havent missed a beat I'm in melbourne and the distributor is in Geelong/Grovedale good price and easy to deal with.
Bursons wanted almost three times as much for the same product.
Gday. Where did you get those park/indicator lights from and how much? Thanks
Greetings.
OzLed Lighting Specialists:
Cheers,
Pass the Popcorn
Nissan Datsun Patrol
Autobahn also sell them for $50 ea if there's one close to you and you can't wait.
1 - 12 of 12 Posts
