Hey guys
Wondering if anyone has done the Gu zd30 to gq 4.2 conversion ?
Did any wiring need to be modified to get the a/c working ? Mine is connected back up but when I push the ac button and have no power @ pump & all fuses n relays are ok thank
Dane
All work done the hard way with blood, sweat and beers
The ZD30 engine ECU switches the A/C on.
You will need to bypass this.
Bit of a thread dig here (8 years, still a valid topic for discussion!) but @Yendor I happen to know you are still around... I've been looking all morning but haven't found out exactly how this is done. I assume I need to bridge something somewhere, perhaps at the loom?
Edit: Can I still run it through the ECU or does that require a tacho signal (which I don't have atm)
Gu TD42 series 3 wgn
Once you get tacho signal it will work.
Needs the tacho signal to work via the ECU.
Not much point in running the A/C via the ECU as the tacho signal (engine RPM) to the ECU will be incorrect now with the TD42 fitted.
To bypass the A/C at the ECU. Cut pin 15 (Yellow wire with a Blue trace) and cut pin 21 (Light Green wire with a Black trace) and join the two wires together.
Thanks mate, that's what I needed. Saved me again. (y)
