Status
Not open for further replies.
1 - 20 of 35 Posts
Hello all, Version 2.5 is now up. Enjoy.
NOTE FROM geeyoutoo* Go to Post #14 for latest link to version in Colour. Do not pass GO, do not collect $200 just go direct to Post #14 :). The link there is to my colour copy.
BROKEN LINKS REMOVED
5-10-12 - 2.5
* Added Rim Offsets
* Added LED Indicator Lights for Bullbar Section
* Added LED Parking Light Bulbs Section
* Amended Fanbelt Section
* Added Recommended Fluids And Lubricants Section
* Added Vehicle Identification Number (VIN) How To Read Section
24-5-11 – 2.4
* Update bubbling dash section.
* Added Oil Filter section
* Added Air Filter section
8-4-11 – 2.3
* Added replacing Nissan steel bullbar indicator and park lights.
* Added section on belt tensioner.
* Added section on drive belt.
* Added section on alternator.
* Updated electronic speedo correction section.
* Updated VNT section.
* Updated trims - silver plastic on doors and dash section.
23-10-09 – 2.2
* Some word changes here and there
* Pollen filter kit
* Plastic door trims – wear
* Cracked Rear Chassis
22-05-09 - 2.1
* Added tip After/During an Engine Rebuild.
* Wheel Terminology formula re-write - just didn’t make sense, does now.
* Earthing Issues
* Speedo Correction
* Cleaned up some text to make more sense in some paragraphs
04-05-08 - 2.0
* Added Tyre terminology
* Added Wheel terminology
* Bubbling Dash
* Winch Considerations
* 5th Gear Failure GU
* Flat Mirror on GU4 (non convex)
* Free Wheeling Hub Diagrams - Manual
* Keyless Remote - Reprogramming
* Trailer Wiring Diagrams
* Mass Airflow Sensor (MAF)
26-11-07 – 1.9
* Restructured to find info easier
* Added section on oil pressure switches
* Added PCV Valve section
* Oil Pressure Sender install
* Oil Catch Can – How To Make Your Own and Install
* Removed the advanced and Expert Turbo 102 & 103 sections
25-9-07 – 1.8
* Added other tyre wear factors
* Added maintaining your tyres
* Updated air filter sections
* Updated thermal fan section
* Added stereo wiring diagrams section
* Added sway bar extension bracket section
3-9-07 - 1.7
* ZD Engine Protection – Oil Catch Can section - Updated
* How To Test If Your Vehicle Is Affected By Over Boost – Updated with new findings
* Why Synthetic Oils are Superior
* GU Drivers Seat Movement
* Steering Castor Correction – After Lift (added technical explanation)
* Intercoolers
* Air Filter Test Report - Spicers Iso 5011 Duramax
* Credit given to those who supplied info, well those I could remember or find
13-8-07 - 1.6
* Additions to Brake Proportioning Valve and EGR.
9-8-07 - 1.5
* Some major additions and changes to the PDF including a big section on Diesel Performance chips.
big red said:
thanks to tuffgu&gq for this ...
Displaying the ECU fault codes. (ZD30) 3.0ltr TDi
1.Ensure that the battery is fully charged and that the engine is at normal operating temperature.
2.Ensure all accessories are switched off.
3.Switch the ignition On but do not start the engine.
4.Bridge terminals 8 (IGN) and 1 (CHK) on the diagnosis connector. The engine waring lamp should extinguish.
Connector diagram (looking front on) it looks like a wiring plug rectangle shape.
Top row
16,15,14,13,12,11,10,9
8,7,6,5,4,3,2,1
Bottom row
Bridging 8 (IGN) and 1 (CHK) with piece of wire (just push it into the slot)
5.Wait at least 2 seconds and then remove the wire bridging the terminals of the diagnosis connector. Any stored fault codes should now be able to be read.
6.Read the codes by counting the number of flashes of the Check Engine warning lamp. The code numbers are displayed as sets of separated by a 2.1 second pause. Each set comprises a series of 0.6 second flashes, a 0.9 second pause and a further series of 0.3 second flashes. The first set represents the first 2 digits of the code and the second set represents the last 2 digits.
Example 1. Code 0102 (Air Flow sensor) would be shown as one 0.6 second flash, a 0.9 second pause and two 0.3 second flashes.
Example 2. Code 1004 (Injection Pump fuel cut out system) would be shown as ten 0.6 second flashes, a 0.9 second pause and four 0.3 second flashes.
Note: To cease retrieving codes or to read codes again, turn the ignition Off and wait at least ten seconds before restarting the above procedure if necessary.
Clearing Fault Codes:
1.After reading the fault codes as described, reconnect the wire bridging terminals 8 (IGN) and 1 (CHK) while the ignition is still On.
2.Wait at least two seconds and then remove the wire bridging the terminals. Any stored codes should now be erased.
Note: Fault codes are also erased if the battery is disconnected for more than 24 hours.
3.Road test the vehicle and check that there are no fault codes stored.
Fault codes
0102 Air Flow Sensor
0103 Coolant temp sender
0104 Vehicle speed sensor
0203 Throttle pedal switch
0208 Cooling Fan control
0301 Engine ECU
0402 Fuel temperature sensor
0403 Throttle pedal position sensor
0406* Intake air volume VNC system
0407 Crankshaft position sensor
0502* Battery voltage
0504 Auto Trans communication line
0701 Injection Pump –cam ring position sensor
0702 Injection Pump –TDC pulse sensor
0703 Injection Pump communication line
0704 Injection Pump –spill valve
0705 Injection Pump –ECU
0706 Injection Pump –spill valve
0707 Injection Pump injection timing control
0802 Engine ECU
0804* Engine ECU
0807 Stop lamp switch
0901 Engine ECU
0902 Engine ECU relay
0903* Engine ECU
0905 Intake air pressure sensor
1003 EGR volume control valve
1004 Injection Pump –fuel cut out system
* These codes do not illuminate the Check Engine warning lamp.
--Andrew
Bit more info on the fault codes complements of mikegq
mikegq said:
Infomation Courtesey of Repco Autotech Encyclopedia 2006
Fault Code Table
Code # Circuit and Status
0102 Mass Air Flow Sensor
Circuit, Sensor or ECM failure
0103 Engine Coolant Temperature Sensor
(excessively high or low voltage at ECM)
0104 Vehicle Speed Sensor
(signal not sent when vehicle is in motion)
0203 Accelerator Position Switch (incorrect signal sent to ECM)
Accelerator Position Switch fault or ECM failure
0208 Overheating Fault
Cooling Fan system failure, Engine coolant re-filling procedure not followed,
Cooling system faulty, Engine lubrication problem
0301 ECM 2, failure (calculation function is malfunctioning)
Internal IC failure
0402 Fuel Temperature Sensor
(incorrect signal for fuel temperature received)
Refer to Injection Pump Control Unit
0403 Accelerator Position Sensor
(out of range signal received from sensor or switch assembly)
Circuit malfunction, Accelerator Position Sensor failure,
Accelerator Pedal Dual Contact Position Switch failure, ECM failure
0406 INT/AIR volume (excessively high signal from Mass Air Flow Sensor)
Air Duct, Charge Air cooler, Variable Nozzle Turbo Charger Control System,
Variable Nozzle Turbo Charger, Mass Air Flow Sensor failure, Circuit malfunction
0407 Crankshaft Position Sensor
0502 Battery voltage (excessively high voltage sent to battery)
Incorrect jump starting, Battery, Alternator, ECM
0504 Automatic Transmission Communication Line
(ECM receives incorrect voltage from Transmission ECM)
Circuit malfunction, Automatic Transmission ECM
0505 No faults detected
Monitored circuits are operating normally
0701 Camshaft Position Sensor
(incorrect signal from the Injection Pump Control Unit)
Circuit malfunction, Injection Pump Control Unit
0702 Top Dead Centre Pulse Signal
0703 Pump Communication Line
0704 Spill Valve Circuit
0705 Pump Control Module
Circuit malfunction, Injection Pump Control Unit failure
0706 Spill Valve
Circuit malfunction, Spill Valve, Injection Pump Control Unit
0707 Fuel Injection Timing Control System
Circuit malfunction, Injection Pump Control Unit failure, Poor fuel quality
0802 Barometric Pressure Sensor (built into the ECM)
Internal circuit malfunction, ECM failure
0804 ECM internal input signal processing function malfunctioning
ECM failure
0807 Brake Light Switch
Circuit malfunction, Switch failure
0901 ECM Failure (calculation function is malfunctioning)
Internal IC failure
0902 ECM Relay (incorrect voltage received by the ECM from the relay)
Main Relay malfunction, Circuit malfunction
0903 ECM Internal input signal processing function malfunctioning
ECM failure
0905 Turbo Pressure
Circuit malfunction, Charge Air Pressure Sensor failure
1003 EGR Volume Control Valve
Circuit malfunction, EGR Volume Control Valve failure
1004 Fuel Cut System
Circuit malfunction, Injection Pump Control Unit failure, ECM failure
1401 to
1408 Nissan Anti Theft System
Refer to Anti Theft system information
Cheers,
Whitie
Hi to all who have put this document together.
Great stuff and very usefull for a new gu owner.
Afterdoing the vnt adjustment what seemed to be a hundred times.........
i found that the adjusting screw actually has a 2.5mm hex key head which makes it so much easier to adjust and hold when tightening the lock nut.
Just thought i would share this with everyone.....
cheers.
nissan patrol gu3
Clean your MAF BEFORE replacing it.
Hello all GU series 3 DI ZD30 owners. I discovered you can remove the MAF sensor & spray Electronic Circuit Board cleaner into the air inlet of the sensor. Gently blow dry & re-install. Clear your fault codes as discussed above & your problem is fixed with power restored. Cost of the cleaner about $15 dollars. It worked for me!
MAF sensor voltages for the 3ltr disels
Here are the pinouts and voltages to test the MAF:
Looking at the back of the connector with it connected to the MAF, the very left hand side is pin 1 which is normally empty and the very right hand side is pin six.
1 - empty
2 - battery
3 - ground (do not use this as the ground of the multi-meter)
4 - Voltage sent from MAF to the ECU (Di - idle to about 4000rpm - 1.5-1.9 to 4v), (CRD - idle to about 4000rpm - 1.6-2.3 to 3.4v) There should be a linear voltage rise as the rpm increase, also, the idle voltages stated are with the EGR in place, expect higher idle voltages if the EGR has been blocked.
For the CRDs
5 - intake air temperature sensor (5v)
6 - intake air temperature ground
On the earlier Di 5 pin models, pin 5 is empty which is on the far right hand side. The MAF output is on pin 1, pin 2 is 5v and pin 3 is ground.
Cheers,
Whitie
MAF Cleaning
First post of the MAF Cleaning thread:
Hi all, it has been a 20k since I blocked the EGR and 13k since I installed the catch can on the truck so I thought I would post an update on the state of the MAF.
As I do an oil change every 10k, I had also decided to take out the MAF for an inspection at the same time as the oil change ever since my MAF failed 20k ago.
This is the first real inspection since I installed the catch can and I am happy to post that the MAF looked very clean compared to the state my previous one was in when it failed which was black everywhere (I believe due to blowby)!
This time I could see both the metal bar and the metal plate that the MAF uses for sensing and calibrating and both looked pretty clean. Since the motor is running sweet, I was tossing up if there was any merit in giving the MAF a clean anyway since it was out.
Well I did clean it thinking that this would be a good test anyway as I did not touch anything else on the motor and when I took it for a drive today - to my surprise, there was a difference! The motor seemed to be crisper as it revved through the range?
I have now decided to clean the MAF at 5k intervals with CRC contact cleaner (purchased from an electronic store), I just spray it onto the metal bar at the end of the MAF and the metal plate just before that bar and let the CRC evaporate. I do not physically touch anything and the spray leaves no residue.
Disclaimer:- I do not believe that the MAF can be damaged by cleaning this way as the electronics seem to be sealed and I am using electronic contact cleaner anyway - having said that, the old saying "if it ain't broke - don't fix it" comes to mind so if you do want to clean the MAF - be aware that we are all responsible for what we choose to do to our motors so it is done at our own risk :bananada:
All the best and hope you all had a great Fathers Day :cheers:
Whitie
Update: For those of us that have not played with a MAF yet, here are some pics..
I Find it easier to remove when I pull up the air filter cover.
After you remove the two screws, you need to wedge a small screwdriver between the MAF and it's housing - pry it open evenly from the top, middle and the bottom.
Spray the metal plate and the metal bar (which you can see better on the picture below) with electronic contact cleaner that leaves no residue.
I also clean the plate at the bottom of the MAF - I do not know it this achieves anything but it gives me a warm and fuzzy feeling to know that it is clean :razz:
Happy cleaning,
Whitie
Reactions: Gotapatrol
Can any body tell me were the air pressure sensor located I have a 0905 and a 0707 code coming up could these codes be related somehow any help would be great I have a 2002 DDTI ZD30 nissan patrol
Darrell,
The sensor is located at the bottom right side of the intercooler nearest the oil filler cap.
My initial though is I don't think that they are related, but with the way the ECU is setup, it could be.
Here is a copy out of my manual on the error code 0905. There are pictures, but not shown here.
Hope it helps,
Smiley69:)
[FONT=&quot]DTC 0905 TURBO PRESSURE [/FONT][FONT=&quot]ZD30DDTi[/FONT]
[FONT=&quot]Component Description[/FONT]
[FONT=&quot]The charge air pressure sensor detects pressure in the exit side of the charge air cooler. The sensor output voltage to the ECM increases as pressure increases. The charge air pressure sensor is not used to control the engine system under normal conditions.[/FONT]
[FONT=&quot]ECM Terminals and Reference Value[/FONT]
[FONT=&quot]Specification data are reference values, and are measured between each terminal and ground.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]CAUTION:[/FONT]
[FONT=&quot]Do not use ECM ground terminals when measuring input/output voltage. Doing so may damage the ECM’s transistor. Use a ground other than ECM terminals, such as the ground.[/FONT]
[FONT=&quot]TERMINAL NO.__WIRE COLOR________ITEM____________CONDITION DATA__(DC Voltage)[/FONT]
[FONT=&quot] _____46____________L________Charge air pressure sensor_ Engine is running.____Approximately 2.0V[/FONT]
[FONT=&quot]_________________________________________________Warm-up condition[/FONT]
[FONT=&quot] _________________________________________________Idle speed[/FONT][FONT=&quot]
[/FONT]
[FONT=&quot]Diagnostic Procedure[/FONT]
[FONT=&quot]On Board Diagnosis Logic[/FONT]
[FONT=&quot]Malfunction is detected when ... Check Items (Possible Cause)[/FONT]
+ [FONT=&quot]An excessively high or low voltage from the sensor is sent to ECM.[/FONT]
+ [FONT=&quot]Harness or connectors (The sensor circuit is open or shorted.)[/FONT]
+ [FONT=&quot]Charge air pressure sensor[/FONT]
[FONT=&quot]1 CHECK CHARGE AIR PRESSURE SENSOR POWER SUPPLY CIRCUIT[/FONT]
[FONT=&quot]1. Stop engine.[/FONT]
[FONT=&quot]2. Disconnect charge air pressure sensor harness connector.[/FONT]
[FONT=&quot]3. Turn ignition switch “ON”.[/FONT]
[FONT=&quot]4. Check voltage between charge air pressure sensor terminal 1 and ground with CONSULT-II or tester.[/FONT]
[FONT=&quot]OK or NG[/FONT]
[FONT=&quot]OK [/FONT]c [FONT=&quot]GO TO 2.[/FONT]
[FONT=&quot]NG [/FONT]c [FONT=&quot]Repair harness or connectors.[/FONT]
[FONT=&quot]2 CHECK CHARGE AIR PRESSURE SENSOR GROUND CIRCUIT FOR OPEN AND SHORT[/FONT]
[FONT=&quot]1. Turn ignition switch “OFF”.[/FONT]
[FONT=&quot]2. Check harness continuity between charge air pressure sensor terminal 3 and engine ground. Refer to Wiring Diagram.[/FONT]
[FONT=&quot]Continuity should exist.[/FONT]
[FONT=&quot]3. Also check harness for short to ground and short to power.[/FONT]
[FONT=&quot]OK [/FONT]c [FONT=&quot]GO TO 4.[/FONT]
[FONT=&quot]NG [/FONT]c [FONT=&quot]GO TO 3.[/FONT]
[FONT=&quot]3 DETECT MALFUNCTIONING PART[/FONT]
[FONT=&quot]Check the following.[/FONT]
+ [FONT=&quot]Harness connectors F6, M51 (A/T models)[/FONT]
+ [FONT=&quot]Harness connectors M88, E106 (A/T models)[/FONT]
+ [FONT=&quot]Harness for open or short between ECM and charge air pressure sensor[/FONT]
+ [FONT=&quot]Harness for open or short between TCM (Transmission control module) and charge air pressure sensor[/FONT]
c [FONT=&quot]Repair open circuit or short to ground or short to power in harness or connectors.[/FONT]
[FONT=&quot]4 CHECK CHARGE AIR PRESSURE SENSOR INPUT SIGNAL CIRCUIT FOR OPEN AND SHORT[/FONT]
[FONT=&quot]1. Disconnect ECM harness connector.[/FONT]
[FONT=&quot]2. Check harness continuity between ECM terminal 46 and charge air pressure sensor terminal 2. Refer to Wiring Diagram.[/FONT]
[FONT=&quot]OK [/FONT]c [FONT=&quot]GO TO 5.[/FONT]
[FONT=&quot]NG [/FONT]c [FONT=&quot]Repair open circuit or short to ground or short to power in harness or connectors.[/FONT]
[FONT=&quot]5 CHECK CHARGE AIR PRESSURE SENSOR[/FONT]
[FONT=&quot]1. Remove charge air pressure sensor with its harness connector connected.[/FONT]
[FONT=&quot]2. Turn ignition switch “ON”.[/FONT]
[FONT=&quot]3. Use pump to apply pressure to charge air pressure sensor as shown in the figure.[/FONT]
+ [FONT=&quot]Always calibrate the pressure pump gauge when using it.[/FONT]
+ [FONT=&quot]Inspection should be done at room temperature [10 - 30°C (50 - 86°F)].[/FONT]
[FONT=&quot]4. Check the output voltage between charge air pressure sensor terminal 2 and engine ground.[/FONT]
[FONT=&quot]OK [/FONT]c [FONT=&quot]GO TO 6.[/FONT]
[FONT=&quot]NG [/FONT]c [FONT=&quot]Replace charge air pressure sensor.[/FONT]
[FONT=&quot]6 CHECK INTERMITTENT INCIDENT[/FONT]
[FONT=&quot]Refer to “TROUBLE DIAGNOSIS FOR INTERMITTENT INCIDENT”.[/FONT]
c [FONT=&quot]INSPECTION END[/FONT]
Hi Whitie,
I noticed you have a K&N air filter... I have heard about the oil in the filters giving fault to the MAF... have you experienced any problems?
Have you experienced increased in performance?
Cheers!:ahah:
You have heard correctly, the way I get around it is after I oil the filter, let it set and install it, I go for a spin down the highway for 10 minutes or so then take the MAF out and give it a clean.
I have not had a problem using that process after I oil the K&N, bear in mind that I only use it for blacktop stuff, in the scrub, I change over to the Nissan filter.
As for any increase in performance, no, you do not really notice it on a turbo diesel, a NA diesel or petrol would be a different story. It does however minimise the vacuum between the filter and the turbo which means less is sucked out of the PCV system (same as when the factory filter is clean).
The main benefit to me is the cost saving because I change the air filter every 10k, with the K&N I just clean it instead.
Cheers,
Whitie
Hi Aksniss, I have experienced a problem similar to yuor described overboost protection. I have a 2006 GU 3.0 TDI. No modifications at all. I was driving at approx 80km per hr and had only been doing so for about half a km. I put foot on excellerator to pick up and nothing happened except the check engine light came on. No picky upy speedy. Kept on putting foot down and still no picky upy speedy. Get to end of road, approx 5 km had to slow down to turn corner. Go around corner and pick up speed okay now to 110km per hr. Engine light stayed on until I turned off ingnition and then when turned back on no check engine light.
Is this the same or similar problem to that you describe.
Many thanks,
Whitie, could you give an opinion on the posssible cause please?
Ta, Mark
Hi guys, just reading all of this info and it's confusing but some of it is relevant to what I have done. I have a 2008 Patrol 3 litre manual and it has started going into limp mode for the past 2 weeks. Today was the worst trying to go to the Gold Coast with nothing short of 20 or more limp modes from Cleveland to Helensvale. Has anyone got any ideas as to what is going on. I have already removed and cleaned the MAF (last week) but no change just getting worse.
Read the section starting on page 12 of the reference document "Test If Your Vehicle Is Affected By Over Boost – How To".
AKSNISS
1995 GQ TD42 NA
Great read for those of us looking for a bit of cheap insurance. After reading your instructions on adjusting the boost I am trying to work out which way you are adjusting the VNT - you only mention turning it, but not which way (in/out).
Welcome to the forum IronSparks. Yep we are lucky we have Akniss (and all our other technical contributors).
Read this topic before you touch anything, then click Geeyoutoo's link within it to see pics and instructions on how to go about it.
http://www.patrol4x4.com/forum/nissan-patrol-gu-gr-10/turbo-actuator-arm-77893/
GU Patrol Reference Document (ZD30 owners look here)
From geeyoutoo. Links are dead, see post #14 for new link to my copy of the colour version.
5-10-12 - 2.5
* Added Rim Offsets
24-5-11 – 2.4
8-4-11 – 2.3
23-10-09 – 2.2
* Pollen filter kit
22-05-09 - 2.1
* Earthing Issues
* Speedo Correction
04-05-08 - 2.0
* Bubbling Dash
26-11-07 – 1.9
25-9-07 – 1.8
3-9-07 - 1.7
* Intercoolers
13-8-07 - 1.6
9-8-07 - 1.5
Links fixed 18/9/2013 documents were moved.
Geeyoutoo EDIT: The original links to the Bible no longer work so they have been removed, I have uploaded a link to my copy of the colour version to post *14
5-10-12 - 2.5
* Added Rim Offsets
24-5-11 – 2.4
8-4-11 – 2.3
23-10-09 – 2.2
* Pollen filter kit
22-05-09 - 2.1
* Earthing Issues
* Speedo Correction
04-05-08 - 2.0
* Bubbling Dash
26-11-07 – 1.9
25-9-07 – 1.8
3-9-07 - 1.7
* Intercoolers
13-8-07 - 1.6
9-8-07 - 1.5
Edit geeyoutoo 30/10/20: Original links to the document are broken, have uploaded my copy of the bible in colour to here:
The Bible Colour Version
BROKEN LINKS REMOVED!
5-10-12 - 2.5
  • Added Rim Offsets
  • Added LED Indicator Lights for Bullbar Section
  • Added LED Parking Light Bulbs Section
  • Amended Fanbelt Section
  • Added Recommended Fluids And Lubricants Section
  • Added Vehicle Identification Number (VIN) How To Read Section
24-5-11 – 2.4
  • Update bubbling dash section.
  • Added Oil Filter section
  • Added Air Filter section
8-4-11 – 2.3
  • Added replacing Nissan steel bullbar indicator and park lights.
  • Added section on belt tensioner.
  • Added section on drive belt.
  • Added section on alternator.
  • Updated electronic speedo correction section.
  • Updated VNT section.
  • Updated trims - silver plastic on doors and dash section.
23-10-09 – 2.2
  • Some word changes here and there
  • Pollen filter kit
  • Plastic door trims – wear
  • Cracked Rear Chassis
22-05-09 - 2.1
  • Added tip After/During an Engine Rebuild.
  • Wheel Terminology formula re-write - just didn’t make sense, does now.
  • Earthing Issues
  • Speedo Correction
  • Cleaned up some text to make more sense in some paragraphs
04-05-08 - 2.0
  • Added Tyre terminology
  • Added Wheel terminology
  • Bubbling Dash
  • Winch Considerations
  • 5th Gear Failure GU
  • Flat Mirror on GU4 (non convex)
  • Free Wheeling Hub Diagrams - Manual
  • Keyless Remote - Reprogramming
  • Trailer Wiring Diagrams
  • Mass Airflow Sensor (MAF)
26-11-07 – 1.9
  • Restructured to find info easier
  • Added section on oil pressure switches
  • Added PCV Valve section
  • Oil Pressure Sender install
  • Oil Catch Can – How To Make Your Own and Install
  • Removed the advanced and Expert Turbo 102 & 103 sections
25-9-07 – 1.8
  • Added other tyre wear factors
  • Added maintaining your tyres
  • Updated air filter sections
  • Updated thermal fan section
  • Added stereo wiring diagrams section
  • Added sway bar extension bracket section
3-9-07 - 1.7
  • ZD Engine Protection – Oil Catch Can section - Updated
  • How To Test If Your Vehicle Is Affected By Over Boost – Updated with new findings
  • Why Synthetic Oils are Superior
  • GU Drivers Seat Movement
  • Steering Castor Correction – After Lift (added technical explanation)
  • Intercoolers
  • Air Filter Test Report - Spicers Iso 5011 Duramax
  • Credit given to those who supplied info, well those I could remember or find
13-8-07 - 1.6
9-8-07 - 1.5
Seeing as most will come in from the front end I have removed the links in the first post (which would not work for me either) and put in a redirect to your post #14, thanks for checking it out mate.
Nissan Patrol GU
Thanks Aksniss,
I downloaded the colour version no problem. It looks like a very useful resource.
Happy 4WDriving
Micknor51 (a novice at this stuff)
Hi Guys,
New member on a thread dig, does anyone have a valid link to 'The Bible'. Both colour and black and white links in post 29 are 404ing.
Interesting, not sure why that isn't working, anyway try this, I had uploaded it to a storage site I use quite a while ago, try it and let me know, there is no preview for this and it is the colour version, as said let me know if this one works.
The Bible Colour.2
http://ge.tt/4V8Pt3L2
Thanks for trying to share these documents with us, but sadly I registered to inform that even that link isn't working now. The counter for nr of downloads, keeps going up but it yields nothing in terms of download.
I would recommend, for example Dropbox or OneDrive, to have a persistent location for these files. Or anything similar of course.
(I could facilitate this if given the documents.)
Oh and by the way, very glad to have stumbled across this forum, with from what I have already seen, is a wonderful bunch of people!
Are you absolutely sure???? I just hit the link I supplied and without logging into my account on that site the colour version of the bible was there, I hit download and it asked me where to save it, seeing as I have both colour and black and white I closed it, try again maybe a different browser? Let me know and I'll see what we can do.
Oh yes, I tried in Edge, Chrome & IE... all of them.
The Downloads counter keep rising and no files get downloaded
And I tried it on two computers, as well :(
1 - 20 of 35 Posts
Status
