Hello all, Version 2.5 is now up. Enjoy.
NOTE FROM geeyoutoo* Go to Post #14 for latest link to version in Colour. Do not pass GO, do not collect $200 just go direct to Post #14
. The link there is to my colour copy.
BROKEN LINKS REMOVED
5-10-12 - 2.5
* Added Rim Offsets
* Added LED Indicator Lights for Bullbar Section
* Added LED Parking Light Bulbs Section
* Amended Fanbelt Section
* Added Recommended Fluids And Lubricants Section
* Added Vehicle Identification Number (VIN) How To Read Section
24-5-11 – 2.4
* Update bubbling dash section.
* Added Oil Filter section
* Added Air Filter section
8-4-11 – 2.3
* Added replacing Nissan steel bullbar indicator and park lights.
* Added section on belt tensioner.
* Added section on drive belt.
* Added section on alternator.
* Updated electronic speedo correction section.
* Updated VNT section.
* Updated trims - silver plastic on doors and dash section.
23-10-09 – 2.2
* Some word changes here and there
* Pollen filter kit
* Plastic door trims – wear
* Cracked Rear Chassis
22-05-09 - 2.1
* Added tip After/During an Engine Rebuild.
* Wheel Terminology formula re-write - just didn’t make sense, does now.
* Earthing Issues
* Speedo Correction
* Cleaned up some text to make more sense in some paragraphs
04-05-08 - 2.0
* Added Tyre terminology
* Added Wheel terminology
* Bubbling Dash
* Winch Considerations
* 5th Gear Failure GU
* Flat Mirror on GU4 (non convex)
* Free Wheeling Hub Diagrams - Manual
* Keyless Remote - Reprogramming
* Trailer Wiring Diagrams
* Mass Airflow Sensor (MAF)
26-11-07 – 1.9
* Restructured to find info easier
* Added section on oil pressure switches
* Added PCV Valve section
* Oil Pressure Sender install
* Oil Catch Can – How To Make Your Own and Install
* Removed the advanced and Expert Turbo 102 & 103 sections
25-9-07 – 1.8
* Added other tyre wear factors
* Added maintaining your tyres
* Updated air filter sections
* Updated thermal fan section
* Added stereo wiring diagrams section
* Added sway bar extension bracket section
3-9-07 - 1.7
* ZD Engine Protection – Oil Catch Can section - Updated
* How To Test If Your Vehicle Is Affected By Over Boost – Updated with new findings
* Why Synthetic Oils are Superior
* GU Drivers Seat Movement
* Steering Castor Correction – After Lift (added technical explanation)
* Intercoolers
* Air Filter Test Report - Spicers Iso 5011 Duramax
* Credit given to those who supplied info, well those I could remember or find
13-8-07 - 1.6
* Additions to Brake Proportioning Valve and EGR.
9-8-07 - 1.5
* Some major additions and changes to the PDF including a big section on Diesel Performance chips.
