1 - 20 of 21 Posts
Very interested in what colour/type paint you used
Very interested in the paint....where abouts are you?
I took mine to a spray painter and they colour matched it no dramas, any spray painter could do it
For those needing to paint the pillar pod, save your money and do it yourself. All you need is some K&H Grease and Wax Remover to ensure surface is clean. Once clean, give it a good even coat of K&H Clear Plastic Adhesion Primer all over (so paint sticks properly) then apply the Paint Match Can (get from any good paint shop). Cost you <$50 and will have enough do yours and a whole bunch of your mates as well. Super easy job, both the primer and interior paints dry with in minutes. You will have the job done in under 30 minutes.
· The Googlest, Apparently!
NP300
Got my gauge pod from Autron, took the pillar trim down to superrubbish and got a can that was almost exactly the same colour, along with some plastic bonding primer for $27 the lot, and did the job. Paint dried and bob's your aunty, you cant tell the difference. A mate who has a very modified Tojo 80 series 1-HDT-FT looked at it and was impressed that I, a new guy to mods, could get the paint to match so well all on my lonesome. Beginers luck maybe!!
Now, just gotta hook up the boost and pyro (probe already installed just before turbo), job for my next trip home.
· Workin for the weekend
I just took one of my grab handles to bunnings and got them to mix up some acrylic house paint to match the colour, got 250ml for ablut $20.
Just paint it on with a brush but need to use a "dabbing" motion with the brush to get the required stipple finnish, plus you will have lots left over.
I have had mine on for about 2 years and has no sign of wear.
Any one intredted in the Ipswich area i have some paint for a GU IV piller.
Nissan Patrol ST
hey, has anyone bought a pillar pod with 3 spots for gauges?
just wondering if 3 is too much, does it block the drivers view and look a bit out of place?
I'm 6'1" and it's fine. Thought it was going to cut the top views of the gauges off but it perfect.
Vehicle Car Auto part Windshield Automotive window part
Nissan patrol
Does anyone know if u can get a single pod. I have a space for second gauge but no plan for a 2nd battery for a while and I have an Autron boost/egt gauge. I'm sick of the ugly hole.
Sent from my iPhone using the hunt and peck method of typing!
NP300
Put something else in it, even a dummy gauge.
Or you could do what a friend did and put a digital speed gauge in there. He, like me, has the steering wheel so low that you can not see the speed between 80 and 140kph and now with a quick glance right he knows his speed.
I could not be bother as I know my speed by where the needle falls across the KPH letters and by revs when in 5th. But my mate drives a cruiser, so of course he needs help in manner of simple things.
1 - 20 of 21 Posts
