1 - 3 of 3 Posts
Nissan GU patrol
New to the forum, was wondering if anyone could help me with this, I've got a 98 GU patrol with a Rd28. I was driving the other night she cut out had nothing, was just cranking not starting got it home, it seems to be fuel, pulled the shut down solenoid out tested it seems to work. New filter re bled the lines to the pump, no matter what I can't get fuel out of the pump, I even pulled the solenoid spring and valve out and just put the solenoid in thinking it would just let fuel through so I cracked a line at the in injector and still nothing, i don't have power to the solenoid so I hooked it up to B+ so its got power whilst I'm testing, is there anything else in the pump electrical that stops fuel? Or am I looking at a shagged pump?
Keep in mind the pump is semi electronic.
It could be an electrical/sensor problem.
Could be a failed crank angle sensor too.
Justin
1 - 3 of 3 Posts
