1 - 3 of 3 Posts
Will a gu1 rear door fit to Gu 4? My rear driver side door has some damage, just wondering if I can use the gu1 door to fit my 2006 gu4?
Discussion Starter #2
I mean the driver side barn door. Will a door from early Gu to fit 2006 Gu?
'14 Y61 ZD30 CRD M/T ST
Yes. All door sheet metal (front, rear and back) is the same but there might be some extra holes / holes missing for some of the trim panels and rubbing strips. However in your case the big barn door will be identical, I think.
1 - 3 of 3 Posts
