I have moved my subtank filler position to beside the main tank filler. Now I have problems with filling the subtank. The bowser always clicks out unless i'm parked on a slight incline. There is only one servo in cairns which has an incline to park on.
Driving me up the wall. Anyone else have this problem, if so any easy fixes, eg bigger breather?
trav.
I sometimes have this problem, but have found if I turn the nozzle to the side (90 degrees) it fills up fine.
It's all about getting the fuel into the tank as quick as possible without backing up, because the air can't get out quick enough. Check for blockages, kinks or restrictions in either fill pipe or breather hose, Also try and shoot the fuel straight down the hose, or lower one side of your rig!
hope this helps.
