Hi Guys,
Need to replace the LHS globe on my GUIV. Have read a few posts and does not appear to be a fun job. I have a Nissan bullbar. What is the best way to to tackle?
Remove the air box?
Remove the light?
Any tips would be appreciated.
Cheers,
Ash
nissan patrol gu4 wagon
I just removed the lid from the air cleaner when I did mine, it is still a tight squeeze to get your hand down to the back of the headlight though.
Bush and Beach-Bum
Removing the headlight is not too hard.
I have only done it on a GU3 but I think GUVI should be easier because the headlight/indicator is one part and there is no trim underneath the headlight which needs to be removed on GU1 -3.
Other then that, as already mentioned, remove the airbox lid and be prepared to lose some skin off your knuckles ;)
to remove the headlight you need to pull the grill first and there is 3 bolts that hold the light on.. not that hard but might be easier to squeeze a hand in tight places
