1 - 8 of 8 Posts
hey guys im not sure if this happends to a lot of trols but withe my head lights the passanger side is duller then the drivers side and i was just wondering how i can fix or counteract it cheers
Do you mean the headlight on the left hand side is duller, as in faded?
Or when the headlights are turned on the left hand side light is duller?
If it is the second one, is it duller on both high and low beam?
yeah the light from the globe is dulles both high and low beam it is getting the same voltage as the right hand side so yeah
If its a GQ... Check your earth... known fault and common to both beams. It can get bad enough to melt the plug
Going by your pictures we are talking about a GU ute?, I would still check the earth as per the evil twins post.
Remove the plug from the headlight bulb and see if it is melted (this can happen is bigger wattage bulbs have been fitted without upgrading wiring).
If this looks ok try swapping the bulbs from left to right and see if the problem changes sides.
1 - 8 of 8 Posts
