Right hand head light does not turn on when on highbeam. The high beam comes on intermittently, when you hit a bump etc. What is the cause of this problem?
Only the right hand, so cannot be the stalk (that controls the left and right hand). So problem can be anywhere from where the left and right hand headlight wires split up to the headlight itself.....
Had a similar issue yrs ago one of the wires was split and touching metal occasionally old wiring. I replaced both headlight plugs with new one's from Autobarn.
