1 - 5 of 5 Posts
nissan patrol gu
hi. I have a 2000 gu and the only way for a big handed person to replace globe l.h.side is removal of the headlight.
can anyone with an arb bulbar tell me if you can remove the headlights completely with the bar in place? I can't with a poly bar.
cheers phil
Rogue
nissan gu patrol
I could with my steel bar (genuine) that sat pretty close to the headlight. Or at least I could get the headlight out enough to rotate it to access the globe easily enough.
nissan 4.5
Yes you can.
Its a pain in the ass but it can be done
I have a TJM T15 steel bar, and I remove the headlight to change the globe.
If you have a std air box, what about removing that instead of the headlight?
1 - 5 of 5 Posts
