1 - 8 of 8 Posts
changing my GU III front brake pads.. so far i have the wheel off hahaha. which is the bolt you undo??..and steps u take to chang pads over?
thanks in advance
Nissan Patrol GQ GU
Mate, really easy.
There is a bolt at the top and the bottom of the caliper in line with the top and the bottom of the pad itself, kinda looks like it is the slide pin that the whole caliper goes in and out on. About a 12mm from memory and it has the fluted rubber over a section of it on the top and bottom.
leave the caliper connected to the diff.
crack the bottom one of the bolts described above then crack and undo the top one and take it out.
The pad cage will rotate out away from the disk and allow you to change the pads, just like peeling an orange.
then bolt it back in and your done.
Changed mine on the side of the road in Alice springs, both sides in 15 minutes. easy as.
Hope that makes sense.
If you dont have a brake compressor just use a good G clamp to push the caliper cylinder back in to make room for the new pads.
Good luck.
yeah ive got it off and pads are in.... and if u dont av a g clamp?? lol
Autos are Superior
Go and buy one
or put your old pads back in and use a very large screwdriver to lever them back in... if you have topped up your fluid in recent times, you wil have to drain some for the piston to go back in.
did the fronts.. started on backs and the f'n bolt snapped in the housing slide thing!!!!!!!!! GGGGGGGRRRRRRRRRRRRRRRRRRRRRRRRRR
Not sure if this is lift kit related but I have a 2 inch lift and need to remove my entire calliper as the calliper hits the steering arm regardless of which way I swing it.
Just thought I'd share my cars odd issues
1 - 8 of 8 Posts
