1 - 8 of 8 Posts
Hello again last week i melted me headlight plugs because of my higher wattage globes went to the auto electrician and he said cut them out and bung in some bakerlight plugs so i did and yes i soldered them in correctly.
Tested them and the result is that they work correctly but the high beam is duller than the low beam and yes they are wired in correctly (compared the filament to my commodore) each filament drops in and out correctly as i turn on and off the hi and lo beam they do there thing but the lo is much brighter than the hi beam. Also over time the hi beam gets duller.
The hi beam indicator light is on all the time when i have hi or lo beam on...
ANY help would be much appreciated
charlie
yer i did a google search and basically thats what ive put it down too. and no both hi beams knackered
· The nutty professor
all i can think of is either
it isnt wired up correctly
there is a bad connection somewhere , ie: headlight stalk , in the wiring or plug , earth
if i remember correctly you fitted higher wattage bulbs to the headlights??
did you upgrade the headlight wiring loom ?? , if not you probly melted something more than just the headlight plug
i would pull the plugs off the headlight and turn the lights on and take voltage readings from the 2 plugs , and also see if the dash light goes out
nah didnt do the loom got sick of not being able to drive anywhere at night so i just whacked them on aight so i suss the voltage and the switch. and yer higher wattage globes
· Premium Member
Y62
I would first make sure that you have the wires in their correct positions in your new plugs.
I noticed in the Safari thread you just posted in that there is a picture that shows this.
When the high beam is on have a look at one of the bulbs, can you see both of the filaments in the bulb glowing?, or just one?
I guess it is possible that the high beam contacts in the switch may have arced them self together, is there a burning smell coming from the switch?
nah only one comes on and they are coming on when they should the correct filiment that is
ok so i had the electronics guy at work test my switch and that is aok :( meaning i have a short in the wire somewhere now i have to chase my tail for a day or so lol
1 - 8 of 8 Posts
