Hey lads,
My n/a td42 has seized going through a water crossing. At first I thought it took in some water but I cannot find any water. I've had the sump off, starter out, rocker cover off and inspection plate for timing gears off and everything looks fine. But the bitch won't turn. Is it possible the timing gears further inside are buggered or a piston to seize for some reason? I'm at a loss and don't know what else to do. You're help and advise (especially from an expert) would be very much appreciated.
Cheers Allan
:headwall:
Cheers Allan
:headwall:
