1 - 3 of 3 Posts
Hi all,
I have a 1991 Nissan Safari Y60 GQ Lwb low roof twin turbo silver top with 35" 1015 -44 muds, Kutsnake flares, 2" body 3"sus 馃槀
Ever since I've had my truck the speedo gets stuck on 60km/h and I have to bash it for it to read properly again. I had the speedo apart when adjusting it to 35s and had a novice look at it, needle feels smooth, circuits look ok. There is a used one for $350 that I might get because I want to get this cert over with, unless theres a fix?
Any tips will help
Thanks!
GPS heads up display would be way more accurate than a Gq speedo (and a fraction of the cost)
Assuming the 12v has the same problem as the 24v, you probably just need to reflow the entire PCB. My 24v speedo gave me trouble and I just resoldered every single joint on the PCB and now it's perfect. On mine I could actually see cracks around many of the joints with a magnifying glass.
1 - 3 of 3 Posts
