1 - 3 of 3 Posts
I am looking to install a boost and EGT gauges into my 2000 3Lt Patrol in the near future. I can install and wire the gauges but will need a little help with installing the sensors.
Can anyone recomend anyone around the southern Gold Coast/Tweed area that can help me out?
nissan/st
Rapson, any exhast fitter should be able to help.
The EGT goes in the exhast about 150mm from turbo and then the boost can get fitted on the first section of pipe work coming out of intercooler.
But as you say you are willing to install gauges and wiring, so just run them thru fire wall around throttle cable exit and zip tie them close to where they will be connected.
Be super careful not to crimp or bend the boost hose to far, i imagine it will be the small clear hosing.
Have fun, are you going the pillar pod???
Garreth
Thanks Garreth,
Yeah was planning to go with the pillar pod, do you have one and can suggest a supplier?
Cheers,
Dave
1 - 3 of 3 Posts
