1 - 20 of 20 Posts
nissan patrol gu
hi all just wondering if any one has had same problem as me with vibration through the hole car it is a 2003 gu i have had new tires balenced wheel bearings done so just after any help if any one has had this problem before and what did you do to fix the problem ???
Triton n Lovin it.
Take it back and tell them to do it properly! :idea:
nissan patrol gu 4x4
Whole car vibration is usually rear wheels out of balance, steering wheel shake is usually front wheel balance.
If there was no vibration prior to new tyres being fitted, take it back
check the tail shafts too. I had a pajero once that had a similar vibration. Eventually found a uni joint on the tail shaft u/s
This is the first question to answer, as FirstGU alluded was the vibration there before the new tyres went on, if not take it back. If it was then we have a definite problem.
nissan patrol y60
if u had gearbox out or shafts out poss out 180 degree can cause this also
nissan patrol gu
Discussion Starter #10
yeah vibraion was there with the old tires im not sure if its the death wobble aswell ?but it is starting to piss me off
nissan gq patrol
Also check the tie rod ends, my vehicle used to drive perfectly. recently when i reach speeds of 89 throught to 100 the whole vehicle shakes. evey wheel is balnced every bush is new, no free play any where. that is until now. the tie rod ens look like the culprit. i can move the tie rod freely by twisting for and afrt. so hopefully new will fix the problem, for me at least. will let you know once change and alligned again.
In that case it is a long involved process, just about every cause is mentioned somewhere below, start at one and keep eliminating one at a time, if you can feel it through the steering then the culprit is most likely in the front end, if not check complete driveline including uni's.
I know you said you had the wheels balanced but did you drive through mud recently, this can cause a problem if it has stuck in the back of the rims.
My money's on rear UJ
nissan patrol gu
Discussion Starter #15
yeah i might just start to change things my car has almost got 20000klm on it so i think it needs a good birthday present
nissan gu
mate I had a vibration thru the whole car that would come & go in my 03 GU for 2 yearsthat I just couldn't find even tnough I had previously replaced them it turned out to be my auto hubs.
nissan patrol gu
Discussion Starter #17
front hubs never would off thought that would be it i might change them to avm free wheeling hubs
nissan gq patrol
Just thought i would give an update, i changed the tie rod ends at last and this seems to have been culprit. Went for a test drive on the same road where it nearly threw me off the road last week, and went through the section with just the ever so slightest movement of the steering wheel.
now just have to wait for the funds to replace the drag link and i think she'll be apples.:coffeeti:
1 - 20 of 20 Posts
