1 - 3 of 3 Posts
I just put in my 2" body lift took it for a drive and when I use the brakes it makes a rubbing noise like as if the tires are rubbing which they arnt as there 33 a/t and I have 4" lift. Cheers!
Need more information man.
Can you feel friction? Can you smell rubber? From what side can you notice the noise from? More information + using correct punctuation, and it'll make it a whole lot easier for us to read/understand what the problem is.
1 - 3 of 3 Posts
