I have been busy with the design of a custom rear bar for probably the last 3 years. It's taking a while because designing it doesn't cost anything and, because it's not really a priority, funds keep getting allocated elsewhere. I'm getting close now though and will hopefully go out on quote for cutting & bending in the next month or so.
I do have a question about high-lift jack points, though. Due to space limitations, I can only get about 50mm worth of RHS into the side of the bar that I want to use as a jacking point. I measured my jack, and the lifting nose is ~105mm long, so about half the nose will be inside the bar.
Question is, is this enough or is the lifting nose going to slip out or even worse, break? I've never used a high-lift jack (frankly the thing scares the proverbial out of me), so I need some input from people with more experience.
