1 - 16 of 16 Posts
hello everyone,
i am in the process of putting a td42 into my GU IV patrol with the zd30 auto.
i have natro td42 and going to boost it.
(i dont need lots of power, just a little boost help haul the rig around)
i have done a little research on here but cant find the right answer.
i am looking at doing all the turbo work outside of the rig so that when i bolt it down its as little as wiring it up from there...
What will be easier for me to go with...High mount or Low mount turbo?
*will have top mount intercooler#
nissan gu td42t
I'd go with a low mount if your keen on a top mount cooler. Gives a lot more room for a bigger/thicker cooler plus more room for dump pipe.
What spec GU do you have? Do you have rear aircon?
i wouldnt have a clue... i didnt get to spend much time with my car before the motor blew. how do i check?
the turbo setup will be all done whilst the motor is out of the car. so i can access everything and make sure its all tight and well sealed.
Ok fair enough. I would go low mount. Makes a few things a bit easier/harder. But seeing as engine is out of car its all good. ☺. Now which low mount are you going?
thats my next question... what a decent budget wise low mount turbo set up that is not cheap crap but not high end gear?
Discussion Starter · #13 ·
how do i know the difference if buying dts kits off fleabay? or who should i talk to locale in toowoomba area?
Discussion Starter · #15 ·
how do i know im buying a low mount manifold?
1 - 16 of 16 Posts
