1 - 1 of 1 Posts
hi, hoping some one can help, first had a problem with motor , read http://www.patrol4x4.com/forum/auto-electrical-37/sensors-make-no-sense-61087/
after new alt, timing chain, tensioner, hoses. i also started putting catch can in but did not realize one of the fittings was blocked, well when i started motor ran for a couple of minutes then stalled, heap of white smoke. worked out it was the blow bye that built up and stalled it. fine disconnected the catch can and motor started fine and smoke went away. now runs fine but now on the idle sits on 45 instead of 24 warm or cold plus i think the running pressures are higher will note tomorrow and post. plus i think there may be more blow bye now.
so can anybody tell me what damage i may have done now. and bye the way still got the original problem just comes in different times depending on needle valve setting
1 - 1 of 1 Posts
