When i have my dieselgas on, not only are my EGT are higher, the temperature takes longer to recover after going up a long climb.
The dieselgas does give me better power and economy, but im making a mental note now whenever i have to go up a long climb (and maybe also when im out slogging it in 4 low) to turn the gas off..
It must make the diesel burn so much more thoughly that it causes extra heat!
I have done the final adjustment on my dawes etc, it is running awesome..
I thought it would too. But i just went out and tested it on the same hill.. same speed, same constant acceleration.
I was out tuning the dawes valve so was mainly looking at the boost gauge to start with, but when i noticed the EGT's getting into the 400's i thought i would give it another go with the gas off - 325-350C. Even pottering arund the side streets the EGT seemed closer to 200 (or less) than the 250 i normally see..
Also very interested to hear what other dieselgas owners experience!
Well I have to turn it off when cruise is on at 100kms, it feels like it cuts in and out of boost with the gas on. Does not show on the taco but you can feel it. Turn it off and its smooth sailing. May need a tune?
Yeah mate, Mine increases EGT with the D-Gas.
If yours is only running into the 400's it's not a concern. Perfectly normal. I Don't like it when mine gets up close to 550.
yours must be wired up a little different than mine as my gas system wont work when the cruise control in on.
The supplier of my system wired the gas to come on when the go pedel is pressed a little(there is a micro switch on the pedel).
Seeing the cruise doent use the pedel to operate the gas system doesnt work.
Ditto that, I talso thought high EGT's are caused by unburnt fuel in the combustion chamber subsequently burning in the exhaust tract..... diesel gas was meant to help burn more fuel in the combustion chamber and hence lower EGT's..... wasnt it?
Maybe timing needs to be reset? Should you run more advance with diesel gas?
Does the engine run hotter?
No. Since more power is being produced the engine does not have to work as hard so it will not run hotter. Exhaust gas temperatures are also cooler since there is no longer excess fuel being burnt in the exhaust system.
it will be intresting to see if the gas system is on with the cruise. It could be that the results they are getting are reversed. (cooler temp at 100 without cruise becasue gas is on and hotter temp under cruise because gas is off)
