1 - 7 of 7 Posts
2001 TB48 GU Patrol
Hi guys does this sound like a duel mas flywheel related problem? When at idle hot or cold my zd30 powered patrol makes vibration like humming noise in the cab and its more noticible with the windows up, also makes the same noise when driving between about 95 and 105 kph. i have been searching about noises that the dmf makes when it is on the way out but im still not sure.
2001 TB48 GU Patrol
Discussion Starter · #2 ·
Bump
2001 TB48 GU Patrol
I have listened underneath the cAr and where the belhousing is there is a slight clanging noise so i thing the duel mad flywheel must be on it's way out.
Go Hard or Go Home
It could be the DMF from what you have described, but have you checked for any interferance between the fire wall and the engine?
I had a new long motor installed in the past & the lifting bracket on the back of the engine/head was slightly fouling the fire wall and gave the symptoms that you described. Mine is an auto though.
If its the DMF, you should be able to rev the motor & the vibration should go away, a clear indication or DMF failure.
2001 TB48 GU Patrol
If I rev the motor at idle it goes away, and the vibration is very much the same at around 100kph
2001 TB48 GU Patrol
I have come to the conclusion that it is the dmf, wondering roughly what prices you guys have paid for the single mass conversion? And anywhere good in brisbane to go to?
1 - 7 of 7 Posts
