1 - 15 of 15 Posts
· Every dog has his day
2005 TD42 GU IV
Can't see why not, but if in doubt, just refit your normal one on the odd occasion you have to use it for recovery purposes.
Thanks Leethal. Seriously Always some butt head ruining it by stealing little stuff. Like they cant afford 20 dollar item
I've been running one of these for probably nearly 20 years both for towing and the recovery hitch tongue. Haven't damaged it yet.
Reactions: drgtr
sweet as. thanks mate
I have had a Talon one for about the same time as Fester, and apart from some scuff marks to the shaft, it looks like it did new.
The only issue I have had with them is that even with dust covers over the lock they still need a spray in the slot occasionally, bull dust gets in everywhere.
Thanks Trolling. What do we spray in there to keep the lock fresh?
After being up north for 3 months and then struggling to get the lock off the locking pin, I sprayed the life out of it with WD-40, let it sit, and was finally able to get the lock open. To be honest I think any liquid would have been ok as it was just carrying the dust out of the lock. I then soaked the whole lot in kerosene thinking it was applying a bit of a coating to the whole thing.
As an after thought I wrote to Talon and asked their opinion, and a nice lady named Laura replied with this information in part :-
As for cleaning the lock with Kerosene, this actually leaves a film in the lock cylinder which can cause the dust to stick making the lock less smooth to operate. Australian Lock recommends the use of Shellite or X55 to clean the lock and then once try use a dry lubricant such as Graphite powder. Any oil based lubricants used in the lock will also cause dust to stick. A form of paint thinner can be used to clean lock although this does cause the cylinder to become extremely dry in which case INOX can be used as a lubricant as it tends to dry without leaving an oily film. Never use graphite if you have used INOX in the lock already as this will also cause the cylinder to cease. As a result I now use Inox.
Talon also recommends a cover to slip over their locks, which they sell for about $4.
Hope this helps.
· Administrator
Are these strong enough to use in a Recovery snatch hitch?
My one keeps getting stolen so I want to use one on the towbar itself and one for the d shackle?
I have one, had it for many years with no issues Just a pain in the arse needing a key........
I wouldn’t use WD40. It’s a cheap crap product. All it does is attract dirt and turn it to rock.
Try using inox or similar. Doesn’t attract the dirt as bad.
After some lowlife stole my original one...I now use the top 3 point linkage link pin from a Massey Ferguson 65 tractor...together with the right linch pin .I remove the tongue and pin when not in use...store them either in shed or caravan boot. The hole in the pin is a good size for a smallish padlock too...but havent used this as yet..due to removing it when unhitched....but this will change when we start travelling I guess.
Cheers Keith
· Premium Member
The R clip in mine is bloody tight. I use a shifter that lives at the front of my drawers to hammer and lever it out. Can't get it out without a tool of some description. I contemplated drilling the pin a bit more but it's pretty theft resistant the way it is. I always have a 2nd pin in the drawers these days as I managed to loose one at LCMP one day. (Left it on the rear step when I disconnected the CT.) Had to aquire a bolt big enough in order to tow the CT home at the end of the weekend. It belongs to my 2nd recovery hitch which lives in the drawers during trips. I won't snatch or winch anyone if they don't have a decent recovery point so it gets used if the stuck person has the right attitude.
I like shiny stuff
I'm surprised with the number of people saying their hitch pins get stolen!!! I never would've thought that's worth the effort. What do thieves do with them...?
Yeah, make you wonder. I've always had a locking pin to stop someone from stealing the tongue. Never thought anyone would want to steal the pin, unless they lost theirs and needed one on the spot.
Discussion Starter · #15 ·
I even remember when LED light bars first started coming out. Bastards were stealing them like no tomorrow. Now since they are cheap and everywhere. No on bothers anymore
1 - 15 of 15 Posts
