Nissan patrol Gu Dx ute
Well I have been havIng problems with starting when the motor is hot or warm. It's starts fine when it cold. It's a 2006 td42i ute. I've replaced several fuel filters including after market ryco and genuine nissan which is on there now, I have also replaced the primer pump with a brand new one. And still got the same problem. The motor has only got 100000 ks on it so surely it's not the injector pump. I also replaced the hose clamps on the fuel lines to the injector pump ans the lift pump. But any suggestions would be greatly appreciated.
Regards jesse
check your glowplug timer. Little know fact: the plugs actually glow for longer than the light is lit..
Check and clean engine earthing point - it may be cranking too slow - good starter and battery are very important for starting hot diesel engine.
x2 with Azotek. When I replaced the starter battery a couple of years back the Patrol started almost instantly everytime instead of hanging on the starter for a sometimes embarrassing amount of time.
Forgot to add I just bought a brand new 720 cca battery that was the first thin I did. the starter I had rebuilt about 1 year ago. Tightened the earth points to the battery as well.
