nissan patrol gr
Hi,
Have an -05 GU that the owner before me has taken off the rear stbilizer, and then f*cked up the thing that control it - just hangin a thing lookin like a handbrake wire with a little spring on it where the stabi disconnect should be by the rear wheel/frame and STABI OFF dont come off how many times l ever press the button:headwall:
My question is, is it possible to take the out the STABI switch in the middleconsol and loop some wires there to get it not to light up??
Cheers //J
Pop the switch and disconnect it and then put it back in. Make sure you insulated the female plugs you pull off. I am however assuming the light is in the switch itself an not up in the instrument cluster. If in instrument cluster as suggested remove globe or see if there is a dedicated fuse you could pull. That would be a dam sight easier if there is such a fuse.
Currently in PAD rehab
Put a small square of gaffa tape or duct tape over it.
The same method seems to work holding my rear bumper on (it's like a patchwork quilt of gaffa tape) so hiding a light should be easy :)
