1 - 18 of 18 Posts
g'day guys wanting to know how hard it is to fit the reduction gears and what you need to do it. cheers
I had 85% fitted a few years ago (by mechanic) I do know they had to use dremmel to remove some of internals of case and was in the workshop for 2 days - hope that helps
fairly straight forward then?
Had a mechanic install my 85% gears about 10 years ago, took him about 5 hours. Best addition to the patrol by far.
Sent from my iPad using Tapatalk 2
Reactions: LordMayhem
And while replacing it, (assuming your transfer case was tip top condition inside) would the only things to replace be the seals at either end - or other stuff too? Maybe a gasket?
Glasshouse Bogan #1
nissan patrol gu
We didn't replace seals but we are hard core so no need. No gaskets required just sealant. And oil you need oil unless you keep the old stuff now that would be hard core wish I'd thought of it.
Nissan patrol gq
How much are the 85% reduction gears & does the kit come with every thing that's needed.
Also are 85% reduction gears the best choice for a go everywhere tourer.
Both 43% and 85% gears require light grinding of the transfer case. Easy peasy with a 5" grinder. If you want to attempt yourself make sure you pick up an assortment of gear pullers. I also found that I had to replace most of the steel snap rings and the brass synchro ring (a few teeth were broken) - so there is a chance you may need to order a few bits and pieces. I also used my 12t press which was invaluable (both for pressing and holding the bastard while torquing the output pinion up to 300 Nm or whatever it is...).
Nissan patrol gq
Ok thanks, I have a 20 Ton press & the gear pullers.
Nissan patrol gq
After driving my truck with 63% gears i'd say that 85s would definitely be too low for sand driving.
Glasshouse Bogan #2
I've never used low range on the beach, is it common for people to drop it back to low range for a bit of sand ?
GHMBC #3
nissan patrol gq lwb,3"lift.
what gear in std do you use low range in sand- 1,2,3 same as mud so with 85% use 2,3,4.I suppose if you ain't hardcore and dont like shifting between high and low it might be a inconvenience, but otherwise go hard haha
It is if you drive a 2.8t!
(edit, I've never driven on a real saltwater beach, but some of the sand I've done here is pretty cruel and wants to keep you.
1 - 18 of 18 Posts
