1 - 3 of 3 Posts
As we are the second owner of a 2008 3.0Lt Patrol (manufactured July 2008, first resisted Oct 2008) & now with 77,654 km, would I be right in thinking this vehicle would be still under warranty?
The reason I ask this is I have a minor coolant leak that I believe to be coming from the thermostat housing and a little moisture can be seen at the coolant return to radiator housing.
Now if it is still under warranty Mr & Mrs Nissan can do their thing and if not I will have to roll up the sleeves and start to operate on the wife’s baby.
Hi, my understanding is that the standard is 3 years so you should be OK. I believe the dealers check the VIN # to check if it is in warranty.
Anthony
Hi. It is under warranty but they will check all service records and hopefully will fix it. I would advise that you get extended warranty if you have kept service record up to date.
It is expensive but this is the time & KM that you will need it.:cool: All the best.
1 - 3 of 3 Posts
