1 - 5 of 5 Posts
I can hear the pump priming when I turn on the ignition...but how reliable are the petrol pumps for the 4.8 GU?
The 2009 vehicle has 40,000km on it...surely the pump isn't dead already?
I hear mine prime every time I turn the ignition to on. Mines aftermarket as I changed it back to petrol from gas. I wouldn't worry too much. They ain't that dear so get a spare if your worried. The sun tank pump will run the engine fine also.
In a bad situation all you need to do is change the power wires over in the control box on the passenger side chassis rail.
Oh to add to that you need to 're run the fuel pickup hose to the sub tank. Sounds like a pain but ain't that bad
Thx.....my issue is related to my other post on why the car won't start but your comments are handy to know in any case! :)
1) To change my pump is a huge job because I have storage drawers in the back.
2) It's possible that my failure to start issue might be because of the flip key have a dodgy component.
The car goes for a service tomorrow...maybe they can shed some light on matters.
If you can hear the pump priming when you turn the ignition to on then I would look at other things but the mech should pick it up in the service
1 - 5 of 5 Posts
