21 - 28 of 28 Posts
1989 GQ TD42 wagon
I think you'll be OK WRT it's strength, as long as you don't go chasing stupid amounts of power. Parts not sure, but I imagine later model turbo parts would fit. N/A parts too if you can't find anything else.
I got everything I needed for my Safari TD42T from Partsouq even the turbo spec exhaust studs & multi-layer turbo manifold gaskets. Also bigger rear crank seal, all hoses, inlet manifold & sump gaskets, etc. They even had a turbo spec piston oil squirter that I had to replace.
89 gq st by nissan
I have a 97 short wheel base with black top turbo in it but also couldn't finde any data on it it was Japanese import and 12 volts but dual battery as it has an electric winch at front by factory and rear diff locker manual transmission
Sent from my M2101K6G using Tapatalk
· Premium Member
Safari Granroad 1993 td42t wrgy60
Discussion Starter · #26 ·
Makes me wonder why some are 24v like mine. Electrically they are very similar. Saw a post here by a guy who listed the differences which were few. Even fan is same 12v on 24v truck
· Safari Hoarder
93silvertop, I have imported a few into Canada and imported the first Y60 Safari with factory TD42T. I can probably help if you need. You will want to disable the EGR system which you can just unplug at the solenoids and the system will go dead.
· Premium Member
Discussion Starter · #28 ·
Thank you. I do not believe mine has an egr but i could be wrong. Will definitely take a look to be sure. Usually I use a blanking plate to stop exhaust gas entering intake.
21 - 28 of 28 Posts
