Took mine off the other week as somehow a small moth had got in there before i bought the vehicle and died.
First you have to take off the dash surround, from memory left and right of the sterring column there is a phillips head screw and some above the instrument cluster, so just slide your hand around until you fell the countersunk screws. Or get the high powered tourch out and youll see them. there are no clips that hold it on.
Once ouve got that off there are about four screws holding the instrument asssembly on, once youve undone them it will come foward a bit and hen you need to disconect the wiring plugs that in the back, there are tabs on the plugs that need to be pressed o release the plugs.
On mine all the plugs were a different shape so you can't mix them up.
the face of the instrument cluster has some very simple tabs that are very obvious so you shouldn't have any problems if you want to take it off to give itl a clean before reassembly.
Have fun
