1 - 5 of 5 Posts
Nissan Patrol GU
Hi guys
when offroad on the weekend my passenger rear door wheel arch trim at the bottm was unclipped from the door by a tree i was squeezing past and i cannot get it back on so trying to find the easiest way to get it back on and i think i'll have to remove it and the clips from the door to get back on
any ideas?
did a search could see anything
thanks
Leon
Gday Leon. Do you mean the rear door flair? I ripped mine of at Barrington Tops a few months ago. From memory they have a phillips head on the inside of door at bottom, and the rest are push in clips. All the clips were pretty cheap from Nissan, but the seal that goes between the door and flair was like $50 bucks, so If you can save it do so.
Nissan Patrol GU
yes the rear door flair mine has just popped of the clips by the looks. so need to take it off to reput it back on all seems to be in one piece.
on the bottom clip on the inside of the door is a black rubber sort of thing how do i get that off does it just pull off?
are you referring to the flare under the rear passenger door. Near where your side steps or rock sliders sit? If so. Does anybody know what clips you need for them? I just half ripped off my passenger side one and trying to find the clips for it.
Thanks in advance!!
Nissan patrol gu
Thanks in advance!!
Nath,
I did the same and bought a new set of fittings, clips etc from
First time I had dealt with them and more than happy with their service and degree of help.
I recommend you get in touch with them.
1 - 5 of 5 Posts
