Hi guys,
Attached are two photos of start motor+solenoid of my GQ RB30.
I'm not quite sure which wire I need to connect to the battery directly to crank the engine.
Wire connected to No 4 on the solenoid is the wire goes into the starter motor.
Even though there are two wires( 1 & 2) goes into the connector plug, there is only one wire comes out of the other end of the connector plug( a white wire with orange stripes), which says either they are both connected directly or one of them( No 1 blue one or No 2 black) is not used for anything or connected to anything.
Can you please help me with some directions?
Also, is there a way to locate that starter solenoid positive wire from upper end of the wire harness adapter, where I can access it easily?!
