1 - 20 of 155 Posts
"Toxic Personality"
This is a Tech thread and will be kept clean, keep general discussion in other threads please.
the idea here is to have a quick easy way to check what your car will look like before you buy wheels/tyres/lift, also should cut down on the "what size lift do i need to fit 35's?" threads.
Rules for thread:
Please only post 1 picture of your car per post.(this is not a build thread)
Car needs to be more-or-less side on.(obviously so we can see what it looks like)
Please copy/paste this template and fill in relevant data.
Patrol Model/Year:
Lift size:
Tyre Dimensions:
Wheels:
Any scrubbing? Yes/No:
Recommended? Yes/No:
Then upload a picture like this:p
Why not join in on this one :D
Patrol Model/Year: 2000 GUII DX
Lift size: 4"
Tyre Dimensions: 285/75/16's
Wheels: 16 x 8 Steelies
Any scrubbing? Yes/No: Yes (just above chassis on inner guard)
Recommended? Yes/No: Yes
Patrol Model/Year: 99 GU ST TD42t
Lift size: 4in Suspension Stuff Flexi
Tyre Dimensions: 35/12.5/15 KM2
Wheels:15in Dynamic Steel -30 off set
Any scrubbing? Yes/No: No, not even in the rear wheel arches and sit perfect in factory flares
LED ZEPPELIN
1995 GQ TD42 NA
Patrol Model/Year: GUIV wagon. 2008
Lift size: 2 inch OME
Tyre Dimensions: 285/75R17
Wheels: 17x8 factory alloys
Any scrubbing? Yes/No: No, since mudflaps were removed
"Toxic Personality"
Patrol Model/Year: GU series 1. 1998
Lift size: 5 inch
Tyre Dimensions: 37-12.50/15
Wheels: 15x10 mickey Thompson classic lock II's
Any scrubbing? Yes/No: minimal
The nutty professor
hey why not
Patrol Model/Year: 1999/2000 GUTD42T
Lift size: 2 inch heavy duty
Tyre Dimensions: 33/12.5/15
Wheels: 15x8 -20mm offset
"Toxic Personality"
Patrol Model/Year: GU series 1. 1999
Lift size: 4 inch
Tyre Dimensions: 35x11.50-16
Wheels: 16x8 Allied alloys.
Any scrubbing? Yes/No: no
"Toxic Personality"
Patrol Model/Year: GU series 2. 2000
Lift size: 2 inch
Tyre Dimensions: 33x12.5-15
Wheels: 15x8 -22 steel.
Rogue
nissan gu patrol
Lift size: Standard
Tyre Dimensions: 265/70R16
Wheels: 16 x 8, 0 offset, standard
Recommended? Yes/No: no
Lift size: 2 inch
Tyre Dimensions: 285/75R16
Wheels: Pic 1: ROH 16 x 8 Steelies, -13 offset - Pic 2: Procomp Alloy's 16 x 8, -11 offset
Recommended? Yes/No: yes (NOT ROH WHEELS)
ROH WHEELS
PROCOMP WHEELS
Lift size: 3 inch
Wheels: Procomp Alloy's 16 x 8, -11 offset
Recommended? Yes/No: YES
Patrol Model/Year: GU series 6. 2007
Lift size: 2 inch
Recommended? Yes/No: yes (just not the tyres)
Patrol Model/Year: GQ / 1996
Lift size: 3" Flexy (6" shocks)
Tyre Dimensions: 315 / 75 R16 (35s)
Wheels: 16" Procomps with standard GQ offset.
Any scrubbing? Yes/No: Nill in "onroad" setup - ribs rear inner guards on full stuff but who cares...
Rogue
nissan gu patrol
Can I suggest that if people want more info on a setup, that they PM the poster. Just to keep it on topic and others dismissing or chatting about stuff.
Patrol Model/Year: 1998 GU series 1 4.5L ST
Lift size: 5" superflex/custom
Tyre Dimensions: 315/75/16
Wheels: stock 16x8 GU wheels sprayed black
Any scrubbing? Yes/No: front none rear minimal
Patrol Model/Year: GU ST 98
Lift size: 4 Inch Dobinsons. 6 inch Shocks. Drop outs and retainers.
Tyre Dimensions: 315/75-16
Wheels: Pro Comp -23 Black Sunnies
Any scrubbing? Yes/No: Yes. Lots. Inner rear. Who cares. Should have bigger bump stops!!
Recommended? Yes/No: Yes!!!
Patrol Model/Year: 2006 coil cab
Lift size: 3"
Wheels: 16x8, 0 offset, CSA Magnums
Patrol Model/Year: GUIV 2004
Lift size: 2"
Tyre Dimensions: 285/75/16 Mickey Tompson ATZ 4 Rib
Wheels: CSA Jackal
Recommended? Yes/No: Hell yes!
Reactions: Lesl
Patrol Model/Year:98 ST 2.8L
Lift size:2" Flexi Coils
Tyre Dimensions: 285x75x16
Wheels:King Rims -13 offset
Any scrubbing? Yes/No: Not yet
The nutty professor
hey why not
And now with 35`s
Any scrubbing? Yes/No: was yes, had to remove the front mud flaps not sure anywhere else yet...
1 - 20 of 155 Posts
