101 - 120 of 155 Posts
Patrol Model/ 1999 s1
Lift size: tough dog 3" with 25mm coil spacers
Tyre Dimensions: 33/12.5/15
Wheels: 15x8 -22
Any scrubbing? Yes/No: no but haven't taken it out on any real hard tracks
Recommended? Yes/No: not really as they look small with the big lift, ill be going 35s as soon as I an afford it.
nissan patrol gu ute
anyone on here got a GU Ute coil front and leaf rear with a 4 inch lift? and explain to me how you did the lift the lift exactly? cheers!
Pass the Popcorn
Nissan Datsun Patrol
It is definately doable. Suspension Stuff sell a 3" flexy leaf off the shelf and with extended shackles you have 4" in the rear. Springs in the front are the same as any wagon. I run 3" C/L with 2" leafs and Ext. Shackles in the rear. You can get leaf spring made to any size you want for a price!
For a eye opener, read this thread below, in order of posting for full enjoyment:
http://www.patrol4x4.com/forum/members-rides-19/timbos-gu-4-2-turbo-97015/
Now this (not recommended but definately a laugh and shows what is possible!)
http://www.patrol4x4.com/forum/memb...d42-dx-trayback-runnin-38s-128042/index7.html
Reactions: Jamie392
ive had a look at the 3" flexy leaf kit from suspension stuff and was wondering if it will sag much? as ive heard they do
Has anyone ever tried doing a spring over conversion in a GU, Im a fabricator so i don't mind cutting and welding mounts.
Pass the Popcorn
Reactions: mmoyle
New Wheels
1999 GU 4500
3"lift
15"x8" neg 22
35" maxxis 762
scrubbing=no
recomender=yes
2" lift (I just think it sits more like higher lift in the front and definitely at the back)
265/70 R16 rubber
7x16 -20 steelies
no rubbing
recommened - yes :)
Patrol Model/Year: GU series 1
Lift size: 2 inch.
Tyre Dimensions: 305/70/16 . BFG KM2s
Wheels: 16X8 Factory GU Alloys (painted black)
Any scrubbing? Yes/No: no.
Recommended? Yes/No: yes.
This... has just talked me out of 35's..
Reactions: A4B
Y61 SWB 3 inches
Patrol Model/Year: GU Y61 3.8 petrol SWB Safari 2014
Lift size: 3 inches Ironman complete kit with shocks, coils, steering dampener, bushes, etc.
Tyre Dimensions: 275/70/16 stock
Wheels: 16x8 Factory GU Alloys
Any scrubbing? No. But there was a lot of vibration.
Recommended? No. Too much lift for an SWB.
Y61 SWB 2 inches
Lift size: 2 inches OME coils, Ironman kit with shocks, steering dampener, bushes, etc.
Any scrubbing? No. Very little vibration.
Recommended? No. Yes, of course.
nissan/patrolgq
you mention the STANDARD GQ offset, is that -22? I have 'standard' i think 6" wheels on my RX3.0 but there appears to be very little offset? Im looking to upgrade with a 2" lift and some 33" Mud terrains. Any advice? Thanks Pearly
Standard offset is deffinatly not -22. Your wheels would be 7" so maybe -13 offset. Get some nice black 8" -22 sunraisers for $50 each brand new. They would go well with the 33s.
Model/year:04 tdi ute
Lift size:5"front,6"rear tough dogs
Tyre size:315/75/16
Wheels:-44 allied thunders
Any scrubbing:yes(removed mudflaps )no more scrubbing
Recommended:yes,wider stance,more stable
Nissan patrol GU
Hey guys,
Anyone know if theres any problems with a 4" suspension lift (will likely be going tough dog foam cells) runs with 37's?? I would be looking at getting a Maxxis Trepador BIAS 37 x 12.50-16 set just as a offroad set for my 06 guiv series patrol. My only concern was if was going to scrub at full flex or whether i needed to do a chop for it.
Thanks for any advice
Model/year: 2013 GU9
Lift size: 2" from ultimate suspension with front radius arms spacers spaced 10mm and 80 series bump stops all round
Tyre size: 285/70/17 cooper st maxx soon to get 315/70/17 Goodyear wrangler mtr's
Wheels: stock for now will be going pro comp steel wheels 17x9 -19
Any scrubbing: Not at all
Recommended: Coming from the last 3 4wd's all having 4" lifts at a minimum and running 35"s, she is going absolutely everywhere I point her. So yes why not!
