1 - 3 of 3 Posts
im plumbing up my ht18 on my td42, I need to know if there is a oil restrictor on the 2 bolt plate that sits ontop of the turbo to feed oil to it.
im reading that sometimes a 1-2mm restrictor is in place but others say its not needed, just bolt a flange up with an 8 or 10 an fitting and its fine
what do you guys think?
I will be running the oil feed from between the engine mount which is a 1/8 fitting
4x4 NISSAN
Ht18 don't have an oil restrictor, only ball bearing turbos need this with high oil pressure. Just hook the lines up full flow.
awesome that's all I needed to know thanks
what if I was to run it with the restrictor?, would it cause damage ?
1 - 3 of 3 Posts
