1 - 20 of 34 Posts
hey all
can some one tell me whether this could fit in a patrol?;-):bowdown:
it a quad turbo v16 out of dozer. with 1500hp.
cheers Finchy
Well you wouldn't need a gearbox with that just a torque converter would do.
Justin
im thinkin just the starter motor be more power than stock patrol motor lol
or like they say: if you put your mind to it anythings possible lol
may need a bonet scoop higher than roof to cover it blocking all vision out windscreen :)
Have oxy set, grinder and welder can make anything fit.
Just not sure how the front springs will go. :D
Quickest Tyre Deflator On The Market
Slide it into the back, do a chain drive and put some blocks under the springs and away ya go, think of the traction with all that weight on the rear!!:D:D:D
hey all
cheers Finchy
Saw a Rolls Royce Merlin in an FJ many years ago, so anything is possible.
BORDERTREK 4X4 & FABRICATION
And redline at 1800
Slide it into the back, do a chain drive :D:D:D
PFFT old fart!!!!!!!!!! chain drive!!!!!!!!!!!!!!!:grinroll::grinroll::grinroll:
Mid mount with trans axle and full on drag/race suspension no need for front lift just a little extra in rear good go anywhere(as long as down) setup
warning remove roof before install!!
Discussion Starter · #12 ·
hmm yes i do to! recon it could give a duramax a run for there money!
So what is that motor a V16 twin turbo Cat? Or something, not that it really matters. It is just friggin big and yellow.
Would love to see one mounted in a GU monster truck.
Rogue
nissan gu patrol
Hahaha, you'ld be lucky to get the oil filters in.
Discussion Starter · #15 ·
its actually quad turbo design. 2 turbos each side
Discussion Starter · #18 ·
:bump:
1 - 20 of 34 Posts
