Someone help girl out!!
Finally getting my gu back on the road after a busted intercooler & also installed boost gauge, dawes & needle valves.
New intercooler had fitting in the front ran a line from this and T piece to boost gauge an dawes valve.
Issue im having is boost gauge isnt giving me a reading.
Pretty sure ive hooked everything up right!
Discussion Starter #2
All the needle on the gauge does is move down slightly when I accelerate. Hope all this make sense!!
Aside from double checking the way the lines are running, maybe remove the line that runs from your IC to your gauge and suck or blow through it to make sure there are no blockages? Can you take a photo of how you have your dawes and needle set up?
Is there any change in the way it drives? Still boosting ok?
