nissan patrol 2.8td gu st
ARB penrith or give it ago yourself with some research from this site starting snorkel should be going on passenger side and go from there...
nissan partol gu 2
??? Usually on the passenger side gaurd. Search will bring up heaps of threads. That's what I did and everything worked out just fine.
nissan patrol gu2
Thanks guys. I should give it a go. Would be the first thing I even attempt without professional assistance.
I followed the above method (1st link) and aside from the hole on the inner wing it was pretty accurate (mine is a 2000 guii zd30 and I have to use a old chisel to enlarge the exisitng hole).
if you add your pootroll model to your signature then others can tell what you may be after
all in all it took me about a day with an overnighter to allow the silicon to dry. those hole saws are cheap as on ebay but take about 2 weeks to arrive from HK
have fun and do have a beer after the big hole cutting LOL
