1 - 7 of 7 Posts
Hey guys.
I have just finished installing my turbo glide set up on my gq td42. I have used a zd30 air box.
All I need to finish is a 65 degree 3" to 3.5" reducing bend. I have looked all over the net without much luck. So why not ask the people who know.
Im in sydney so where sells intake piping and bends ???
cheers. DEZ
you can use a 3.5 inch bend, then use a 20mm length of 3 inch hose in the smaller end.
clean them both with some solvent and clean rag then just shove it together and clamp it up.
It won't work for boost but will be fine for an air filter connection provided there's not too much movement.
if ya can get the 3.5-3 in a straight go to a peformance shop and get a bit bent up the just get the reducer on one end and a straight on the other.you are better off using metal for your beds ect any way rather than joiners.
just my opinion
1 - 7 of 7 Posts
