1 - 5 of 5 Posts
Hi All,
Wondering if anyone in Brisbane (or close surrounding suburbs) would be able to help me out (sell me :) ) some GQ interior trim parts for my Y60 ute.
From the research i have done ive seen that many parts are interchangeable between the two models.
Ive put an add in the 'wanted' section aswell but figured i would chuck it up here to see if i cant speed things up a bit.
Im after the following parts:
  • Stock steering wheel, (grey)
  • Steering column trim, both upper and lower pieces + screws (grey)
  • Gauge cluster surround trim + screws (grey)
  • Manual gear box shift lever + rubber boot
  • Glove box lid with hinge, screws and working lock
Plus perhaps some more bits and pieces that i have forgotten about (cough ARB steel winch bar, cough :D).
Please, if anyone is parting out a GQ or has these parts send me a PM and we can work something out.
Cheers,
Hairy :punkrock:
good luck with the steering wheel, the foam goes loose so they are sought after. Best bet is a wrecker for that. Nissan pulsar steering wheel is a popular swap. most nissan wheels will fit.
I have a grey dash surround in Perth but due to the bulk postage will be a bit.
for the column trim try nissan genuine, they tend to be cheap for bits like that. otherwise I think I might have one somewhere.
· Premium Member
1995 GQ TD42 NA
Member 'Purplebus' might be able to help you out, send him a PM. He sells all sorts of parts and is at Glasshouse Mtns.
1 - 5 of 5 Posts
