1 - 20 of 43 Posts
I've read a lot of posts on this site regarding fuel economy and all that stuff. I haven't owned my patrol long at all so am pretty new to the whole diesel CRD engine thing. I recently filled my main tank up and between a long trip to Warwick and round town stuff I have gotten around 650k off the main tank. I figure this to be around 13.5 to 14 l per 100klm. Is that excessive???. I do tend to tread heavy with my tight foot to?
Daniel
Nissan GU1 4.2
I get a constant 14 to 14.5lt over the last 10k. I am happy with that considering the weight I am carrying and that my engine is still stock (at the moment)
On the long trip segments I notice that much better economy is achieved at 100km/hr compared to 110-115km/hr speed. (eg 11.5 L/100 km compared to 14.5 L/100 km)(this is fully loaded, 4 people all camping gear, frig etc etc) May not sound a great difference to some folks but if you put in several days at 600-700km per day then the $ s start to add up.
Anthony
Mine has the two extremes. City driving (which around here is very stop start, hilly etc) we only get 550-600klms. On the highway, even loaded up, we get 850 klms out of the main tank.
850km from the main??? That's about 9.3L/100 which is unheard of. Are you sure that's correct.
Wouldn't it be about 11.1 litres per 100km? Which is reasonable. I've been in the 10s a few times. But mainly 11s.
Sent from my GT-I9505 using Tapatalk
If it were 11.1 then he'd need to pull 95L from the main tank. Given that it's an 85L tank at max capacity then realistically only pulling 80L from it to do 850km.
I'm under the impression that it is a 95 litre main tank? I could be wrong though and it wouldn't be the first time ;). 95 main and 30 sub = 125 total.
Im pretty sure its a 95lt tank which would mean it runs at about 11lts per 100klms.
:rolleyes: We just went through all this tank size thing in the sub tank poll 95L main and either a 30 or 32L sub for Australian models only, conflicting documentation (the 30-32L number is what you get when the pump cuts out automatically).
I get 11 with my 4.2 TDi, seems CRd's are poor on fuel to me
Discussion Starter · #16 ·
Hi Guys
Switched the dub on when the red light came on Today. Klm were around 670 before. The dub filled main tank to just over 1/3 full. Does anyone know how many litres are left when light comes on. Ruck now has done 860 klm and still 1/4 main tank left.
Daniel
Hi Guys
Daniel
About 10 I believe.
subject
I'm watching this thread with much interest...mainly to work out the difference between the European and Aust spec Patrols. We don't have sub tanks over here and my handbook states my tank is 92 litres...filled to overflowing and driven until the needle hits the empty mark, it consistently takes 85 - 86 litres. (it has a warning light, but I've only ever gone down that far once).
Mine is only the 2.8 turbo version (2001), manual trans, with aircon (which is mostly on), so I do expect to get a better result than the bigger diesels. After an earlier disaster, I replaced the motor with a brand new one, straight from Nissan in Japan and it's travelled just under 10K kms now.
A test I just completed today showed that with around 600kms of highway driving, 5 adults and luggage at speeds up around 120 (limit here is 140 kph), about 250 kms of tarmac country roads (speed limit 90 kph) and the rest was off road, rough as guts, normal stuff, plus a very small amount of in town driving (less than 20 kms).
I've done this test a couple of times since fitting the new motor and the result has always been similar. Distances are checked via my Garmin, local EU road maps and the odometer...always the same result!
Distance travelled from totally full, to needle on the empty mark = 953 kms to 1024 kms.
How does that compare?
Hi Guys
Daniel
I was thinking 15 litres left when the light comes on. I've done it a few times now - light comes on, drive it around a bit more maybe 40-50km, fill up and it uses 86 litres filled to the neck. Maybe someone else has documentation to state at which point the light comes on??
1 - 20 of 43 Posts
