Di GU series two ZD30 - just want a straight answer, someone please tell me if 14-15 pounds of boost are safe to run on the grenade? yes or no? as i've heard it's to lower boost to run and will strain the motor, but in fact if i run anymore than 14 psi for longer than 7 seconds, goes into limp. my patrol is stock, apart from butterfly blocked, egr block, tillix - (bleed valve running into cabin for on the fly adjustments), 4" pod filter to a 4" 90 degree staino bent reduced to the MAF sensor inlet size with a forefront induction behind that to turbo inlet.
