Is a Catch Can Really Necessary After EGR Block?
The gunk buildup inside the intake is attributed to having oil vapour mix with exhaust gas. If you remove the exhaust gas from the equation (EGR Block), does the oil vapour just pass harmlessly through to the combustion chamber? I would have thought that it might provide a good bit of lubrication to the intake side of the turbo and also the intake valves.
There seems to be a lot of knowledgeable Patrol owners on here that block the EGR and still run catch cans. What am I missing?
I just finished installing my EGT and Boost Gauges so the EGR block is happening shortly and I'm trying to plan what other mods are essential without being a needless spending exercise.
Thanks in advance for your thoughts.
