G'day, I have a TD42 cab chasis, when I go to turn the ignition often I get nothing other than a click. I'm thinking starter motor or solenoid. I tightened the connection at the starter motor which seemed to help for awhile but the problem is back intermittently, including while launching a boat which took some time for it to turn over again. Definitely not the battery as jumping it makes no difference, either it cranks, often gingerly or nothing other than a click and then sometimes it will fire again for no apparent reason. Im thinking it is either the starter motor or solenoid, is it worth replacing solenoid or am I looking at a whole new starter motor?
