1 - 5 of 5 Posts
hey guys just have a question about the key reader on my 03 gu zd
long story short i turned the car off after an hour of driving, went to get in it after ten minutes and bam cranking over but wont fire
so from what ive read i can get either get a new or second hand key reader and get a locksmith to reprogram my key to it withouth taking it to a local stealer and have the charge me an arm and a leg
(ive had the key tested and its working fine)
any info would be great
cheers fellas
Swap circuit board from your original key reader with replacement key reader unsolder very fine wires .reconnect to original pc board re assemble cover .should work fine .transponder is in circuit board .coil is standard .fine wires of coil get damaged, key wont work.if your coil housing is not to damaged approx. 60 turns of simular copper varnished wire will let you remake coil.
Worked for me.
2010 ZD 30 auto
Hope this helps.
Bigmacca
2010 GU DX CRD Grenade :)
Nice thread mine, but good info. You would hope he has sorted it out in the 2 and a half years since this thread was started.
It's all good. That's what forums are all about. Hopefully geeyoutoo sees this and can put it into the archive in case anyone else has this issue.
1 - 5 of 5 Posts
